Yea, I'm afraid I'll be doing any wiring needed on his trucks now.
We ran his much like you did morgan. Took out all the stock battery cables, ran a new ground from the head to the frame. Battery terminates at the starter solenoid. Moved the end of the alternator-to-battery wire to the starter solenoid. And grounded the negative of the battery to the frame. Has worked fine once all the connections were solid and not grounding the positives.
I've got most of my supplies ordered up, I'm using 0 gauge stereo power wire I managed for about 1.60/foot The run from the starter to the kb relocate plate is just under 8 feet, so it shouldnt be too bad with the big cable.
Im going to replace the power distribution block on the firewall with a series of stereo distribution blocks. One that takes the 0 gauge from the battery, and powers out to the starter at 0 gauge. then 4 4 gauge ports on it. 1 will run to the alternator, and anther will go to an accessory power block. The alternator wire that powered the original power dist block will be the source for one of the new power blocks. Keeps only one wire on the starter, the fusable links still work as they should, and allows me to tap for more power in a well powered, organized and easy location.
general info about the battery wires:
battery positive: 3 wires, 1 goes from battery to the alternator (mid sized wire), and the larger goes to the starter solenoid. the smallest (which goes forward through the radiator support (has a single wire weather pak on it) powers the abs box.
battery negative: 3 wires, big one goes to the back of the head on the pasanger side. the other two go toward the radiator support. One grounds to the rad support right there (doesnt go far), and the other follows the abs power wire accross the under side of the rad support to ground the abs box.
The power distribution block on the firewall gets its power from a fusable-link protected wire off the alternator. that power block then feeds power to the fuse box for all the accessories and stuff (2 wires on one connector). And it also feeds power to the under hood light.
Theres another wire coming off the alternator that has an in line blade type fuse that powers the intercooler pump. I believe there is another fusable link wire coming off the alternator that powers the lighting, although im not sure about that off the top of my head.
Hope that helps anyone whos trying to figure power/charging out.
