s10blaza
BOOSTED
So I finally got all my code 59 stuff up and running and the PLX showing readings in tunerpro. I start messing with the F28 table, take it out for a quick drive down the street, it stumbles and dies. It started back up but missed the entire way back. Now it misses at idle and the Actual AFR won't budge from 10.00
Check engine light isn't on but under Malfunction Word 1 I have ones next to Code 24, 21, 15, 14 and 12
I'm at a loss, I have ripped everything out, and reconnected everything just "hanging" I have good grounds, I'm getting readings of mid 500 mVs in tunerpro but the actual AFR deal wont move. I have the correct o2 sensor selected.
Another weird thing. If ALDL isn't actually connected, it'll say the cable is working properly. Hit connect, ALDL connects, I get every reading except the Actual AFR and if I test the cable, it says cable not found. I have re-downloaded all the bins and files from code59 in case anything went corrupt.
Any and all help will be appreciated, thanks guys
