ACdelete-no pulley for Pass. side
TYTILIDIE
METH HEAD
So I get a bunch of people asking me how to do this and Ive decided to jsut post it up.Now keep in mind that I do sell these kits but stopped advertising simply because so many people inquired but only 5 people purchased and I got tired of answering the empty PM's. I have my own landscape business so I rather just make them for the people who really need them and are serious about it instead of just probing me. No need for probes anymore, here is the info you need to make your own if you dont wnat to pay for someone to do it for you.
PARTS needed:
1-piece of 3/8" all-thread
1-3/8"x2" nut
1-3/8" lock washer
5-3/8" flat washers
2-3/8" nuts (with locking on BOTTOM of nut)
1-3/8"x2" bolt
1-3/8" R. hand thead rod end
1-3/8" L.hand thread rod end
1-3" long sleeve drilled for the rod ends (you are going to have to let a mchine shop handle this one)
1-New belt, Gator back preffered. I cant give a part # because everyones truck is going to be different and not everyone is going to cut the bracket exactly like I did. It is all a tight fit for sure but once you get it figured out its awsome.
We'll start with the removal process. What needs to be kept in mind is that this has not been tested (to my knowledge) on a truck with a mechanical fan so electric fans ARE preffered.
REMOVAL:
1. Disconnect your ( - ) battery cable.
2. Remove your Alternator.
3. Remove the ALT bracket that bolts to the exhaust manifold - now this is a part you dont have to do but if you want to keep it you will have to slot it. I tossed mine years ago and never had any problems.
4. Remove power steering pulley from pump. You can rent a pulley puller for free at Auto Zone.
5. Remove 3 power steering bolts. At this point, the pump should just fall down and you may have to wiggle it some to get it out of the way.
6. Remove ALT / PWR STR bracket. There are 5 bolts.
7. Remove AC compressor.
8. Remove idler pulley form the AC bracket.
9. Use a deep wall 9/16" (I think, its been awhile) to remove one of the nuts holding the AC bracket in place.
10. Remove remaining bolts holding bracket in place. Now on my truck, I couldnt get the lower bolt off w/o removing the radiator hose. So to ensure that I would never be tempted to re-use the AC bracket, I broke the bastard off then removed the bolt. Abe's truck was different, him and Austin got the bolt off with some time and patience. Patience I didnt have. So this is up to you.
11. Remove the upper right WATER PUMP BOLT. Some folks find this confusing :lol:
12. Now you are ready to hack up a new ALT bracket. Here are some pics I took. If these are real confusing, I have another bracket ready to be cut for sale and I could cut it up tomorrow and take pics as I go along.
Here is the bracket showing where to cut, its quite a bit and is very difficult
And from the side
And the front. Sorry my MSPAINT skills suck.
INSTALLATION:
1. Install the newly hacked up ALT bracket. You should have retained all 5 mounting bolts, if not, you did somethign very wrong.
2. Install the Power steering pump
3. Take your ALT and drill the left hole (passenger side) to 3/8" or 7/16". You need to do this so that you can use it as a pivot when tightening the tensioner.
4. You are going to have to take the piece of all thread and measure the line up of the lower tensioner mount to figure out where to cut it. If I have to take mine apart I guess I will and give detailed measurements. Now take your all-thread and screw it into the upper right water pump bolt hole. I left an extra 1/2" so I could tighten it with some pliers.
5. Place hte lock washer over the stud.
6. Now take the 2" nut and cut about 1/3 to 1/2 off. Then screw it on the stud and tighten it against the lock washer.
7. Install one flat washer.
8. Install your tensioner.
9. Install another flat washer.
10. Install a locking nut.
11. Place your ALT on the bracket and retain with the long bolt but dont tighten yet.
12. Grab your 3/8"x2" bolt and install on flat washer.
13. Insert this bolt into the drilled out hole on the ALT.
14. Place one flat washer on the other side.
15. Slide bolt through the other end of the tensioner.
16. Install a flat washer.
17. Install your other locking nut on the back side.
18. Install your belt with the tensioner totally collapsed. Over the crank, under the water pump, over the ALT, over the PWR STR PMP and back over the crank.
19. Adjust your tensioner til belt is firm then tighten all your nuts and bolts that deal with any kind of adjustment.
20. Hook your wiring back up and your bat cable and you should be done. Here are some finished pics of what it all looks like.
This shows how the bracket gets cut up
And another
This is what it should look like when completed
The belt can be a bitch to get on so it may seem like your belt is too short but I had to pry mine on and there was plenty of adjustment even under the circumstances. If anyoen feels they really wnat to do this but doesnt think they can I will buil;d this kit for $210 shipped (in 48 ofcourse). Otherwise good luck and let me know how it goes. I love to see people do this because its a true delete IMO, no crap on the passenger side, period :tup:
TYTILIDIE
METH HEAD
Re: ACdelete-no pulley for Pass. side
Clicking on them is as big as they get. I can re-do them if need be. They were so damn big on paint I shrunk them down and didnt realize they would be that small.
AUSyTyIN
Unbusted $#it box
Dude you suck at pics. You need to crop the pic so the boarder of you picture is the boarder of the image (does that make sense?)
SY2932
Administrator
I concur
! If you want, you could send the pics to me and I can host them for you. My email addy is in my signature... THANKS for the SWEET write up! I vote one for the vault :cool:!
Flyin Ryan
hated cuz he drives fords
Mike,
when you used image shack you could have just selected what size you want them resized to and it'll automatically resize them once uploaded.. just another thought.. or I could post my pictures if you'd like
Flyin Ryan
CKEITH said:
someone please re-size the pics.
You can't unless you have a high dollar program like the feds use that will do it without distorting them too death
Flyin Ryan
CKEITH said:
if mike emails them to someone who can host them they will be bigger.
true providing he still has the original sized pics.. he could also go take new ones I guess then up load them to imageshack and select what size he wants them resized to wihch imageshack will do for you
however it's done...i just need so see bigger pics. :tup:
i also have a line on the tensioner rods...polised alum with both rod ends for about 30 bucks...so was gonna take the parts list and make a install kit...make a few bucks on the kit...donate the proceeds to mike for the time and efforts put into it to make everything...and all you have to do is modify the bracket and not have to hunt down a bunch of parts.
all of this after o.k.ing it with mike first. but that was my plan.
TYTILIDIE
METH HEAD
Sorry havent looked at this thread in a while :oops: Ill repost the pics, I have still have them in my camera. No need to send me any money, people wont really buy this stuff Ild bet. I had atleast 20 people PM me about and I sent pics and everything and most ended up either getting the RPM kit or the compressor delete pulley. No big deal really though, I just thoguht it was an awsome idea and was clean.
SY2932
Administrator
Well, intend to make a "donation" of sorts for all your time and effort
. We can discuss the details via PM's...
TYTILIDIE
METH HEAD
OK I just edited the pics, thats about as good as its gonna get folks. The main reason I sold this initially is because when I figured out how to do it it was from somone elses truck and I was utterly confused abotu a lot of things. Cutting the bracket alone is a HUGE PITA!! Sawzall's dont go through it very well and it tears grinder wheels up super fast, it get s very hot and throws crap EVERYWHERE. But, I figure half the people out there trying this on their own will go through it smoothly while hte other half may end up making a couple trips to the JY to buy new brackets they screw up :lol: . ALso, the diffrerence in the tensioner itself is going to play a part in all this. Some guys used turn buckles from Home Depot, thats just plain ghetto but if it wokrs then who can complain I guess. Its about $6 compared to about $50. As far as any donations go, Ild just be happy if SYTY.NET recognized mine and gave me my bigger avatar :rant: :lol:
TYTILIDIE
METH HEAD
Not much but its not a problem I can tell you that. This set up has no fan to spin.
MIGHTYMOUSE
Turbo F body guy
so this would not be good to consider for one who has the original fan; may cause the belt to slip..
TYTILIDIE
METH HEAD
I would imagine so but I dont know for sure as I have never tried it. Why would you want the mech fan any way. Its nice not having all that crap there.
