mrweelr
So I finally got my truck running strong with this new motor and lovin' the Prime Gears 80e, but need to fix the following issues:
1. TCC lockup at part throttle cruise is very hard. I'd like to soften this up. Is it the TCC Lockup Rate (% per second) I need to lower to adjust this? I only want to soften it at cruise, not WOT.
2. If I punch it going ~35mph, it sometimes downshifts into 1st and then revs to the limiter and won't upshift until I let off and get back into it. I think the 2-1 downshift table or 2-1 WOT downshift MPH may need to be tweaked.
Below is a pic of the starter calibration George sent me with the 80e. The only thing I've messed with since installing the trans is to lower the WOT shift RPMs slightly and raise the part-throttle TCC lockup mph to 50. Let me know if anything stands out or looks incorrect.
Thanks
Thanks
