PA 4.3 Typhoon Block
Slyclone
Well-known member
Offering out there a 93 Typhoon block. LB4 code. I have the rods/pistons/crank/block/main caps.
Crank was polished and checked out in great shape. Needs std. Size bearings. Block was degreased as well as crank. I painted the block high temp flat black.
Cylinder walls need a .030 overbore to be right.
I have the paper work on the work that was done. The block was ready to be rebuilt and I left off there.
I have a small pile of stuff including new oil pump, brass freeze plugs, some threaded plugs reccomended for the inside and the remote oil adapter on the block.
This is something I am never going to use and some one else might want to start a build.
If interested pm me.
Slyclone
Well-known member
Re: 4.3 Typhoon Block
I got a few inquiries on the block.
I am looking to get $350 for what I have. Some one has showed interest some what local so I am going to wait on that member. Shipping would probably run $100-$150 via freight.
I have $300 into the block for partial dissasemble, cleaning, measuring, polishing so on... Paper work to show as well.
Here is some of the included items" not everything" http://www.syty.net/forums/showthread.php?t=102970 ( Melling oil pump pick up tube, Milidon High volume oil pump which is de bured and polished on the inside, Rear main seal gasket kit, Brand new Victor Intake manifold gaskets, ans some federal mogul brass freeze plug kit.)
I have a flywheel from the engine, the front balancer, and a box of misc hardware including the rear main assembly, and some other stuff I am probably forgetting.
