18 degree gaskets on Votecs ?
Ty 1885
Will an 18 degree intake gasket fit a ported ( FELPRO 1203 ) Vortecs ? As far as length
goes? (Top to bottom)
bezerk
Re: 18 degree gaskets on Votecs ?
you need 1203's with vortecs when the lower intake is converted
Ty 1885
The 1203's are too thin for my set up. The intake has been cut several times and now sits abit low on the heads. I had to longate the bolt holes for them to line up with the holes in the heads. This maybe why its not sealing the botom of water holes, and leaking into oil.
If 18 degree gaskets line up with the Vortecs, i can then order thicker ones.
FELPRO does not make thicker 1203 gaskets.
SpoolingTurbo6
Searching for this same issue (2019) I'm having to double up the felpro 1203 ans silicone them together. Don't forget .. Use extra silicone between block and intake.
Typhoonracer
Old Guard GURU
I had a set of aluminum "gaskets" (shims really...) made to make up the difference... about 3/16th thick, use 1203's on the head side and silicone on the intake side... I did not have to have modify my lower beyond opening up the intake ports....
