Re: 100% duty cly.o2 corr. 25% WHY ???
John posted a while back that the FAST had a bug when it came to duty cycle (being represented wrong).
Is that what you're running int?
Is is with the FXI only. The classic (or speed pro model is fine). I had to run a double pumper (later an A1000) pump to get enough fuel. I don't think a single 225 is going to handle your setup at full boost.
A couple of things to check:
Make sure you are getting an extra lb of fuel for each lb of boost.
Make sure that you are getting 13+ volts at the pump.
Make sure that your fuel filter is fresh
Make sure you have at leat 1/2 tank of gas
If you are low on fuel delivery then your injector pulse width will open longer as it looks for more fuel, which can show a higher duty cycle. You have to make sure you have a constant fuel pressure load to the rails. I run my pumps at 14 volts at all times which puts out a higher flow/pressure.
You can also raise your fuel pressure to 45 - 50 lbs as your starting point to get more out of your injectors (if the pump can handle it), If you raise the starting fuel pressure you will half to retune your tables.
John
