1BADSUV
I have the 17x9.5 ZR-1 style wheel's off a 96' Camaro SS. I did a search and did not come up with an answer to my question. I am having a balancing problem and my wheel's are straight, also added a set of Sumitomo HTRZ's in 275/40/17. The installer is using a new Hunter-Douglas high-speed balancer on the rim's. Did anyone else with these rim's have to use weight's on the outside? My installer is using inside weight's, so they will not be scratched on the outer-edge of the rim. The rear's have a 1 1/4" spacer so the wheel's look correct. Any info would be appreciated.
Joel
Joel
