boobiedaddy
Of course a pair. Thanks
On a SyTy 3" drop leafs will be 1-1.5" drop. Anything lower will have to use lower blocks or different rear suspension.
X2. Was just going to add that. I bought "3in drop" leafs for my Ty and it barely dropped it an
Inch and a half. I put a half in block on top of the wedge to get the look I wanted.
You're better off buying angled/centering/drop wedges.
I have a set of flex form's if your interested in them. $150 plus shipping. Brand new,
I may be interested, can you give me a shipping cost to 18929. What spring rate are they?
thanks,
Even though blocks are cheaper, I would do the lowering springs first then add blocks to the lowering springs if your trying to achieve a 3" drop on a SyTy. Belltech's with a 1.5" block will ride better than the stock spring with 3" blocks.
if your looking to buy them, Summit sells them for $120 each.
Not sure on the spring rate. They are brand new.never bolted into anything. How's $45.00 for shipping sound? I'm taking a guess on that,I might make a few dollars on that or loose a few.
