Won't start
graham1524
Well-known member
So a few weeks ago the truck was idling while i did a little work because we dont have tags yet so drive it very little until its perfect soo it started to sputter and cut off started after that but with gas it would bog and quit then would not start again to day the fuel pump and filter were replaced and still would not start any ideas?
my dad said perhaps the ignition module what do you guys think
1madgumby
Re: Won't start
Sounds just like the fuel pump to me. take the shrader valve off the fuel rail & put A rag over it & have someone JUST TURN THE KEY ON, DO NOT TRY TO START IT. & see if you have fuel pressure at the sharder valve.let me know if that is it.
graham1524
Well-known member
Re: Won't start
after install we tried starting it then hit the valve and the air pocket came out and then gas started to so we tried starting it again but still nothing
12sec ss
Re: Won't start
Mine did that when I bought it, turned out to be a melter fuel pump relay/plug...
Syclone#2960
What ever it takes!!
Re: Won't start
There is a wire on the firewall next to the hot post. Plug a paper clip from that test wire to the hot post. It should reach and see if that helps. This will simply by pass the fuel pump relay. The relay is located on the driver side next to the brake solenoid. HTH
Flyin Ryan
hated cuz he drives fords
Re: Won't start
I agree apply 12volts to the fp test port behind the upper intake, see if the fuel pump turns on or swap the relay.. it's one of the two above the brake booster.
also do you get your CEL lights when you turn the key to the on position? if not it's your ignition module (located under the dist cap)
SY2932
Administrator
Re: Won't start
Yup:
"Applying 12 volts to fuel pump test connector to troubleshoot fuel pump or set fuel pressure with vacuum line still connected and motor off (note fuse for safety)."
The part number for the ignition module is 1048-2827.
graham1524
Well-known member
Re: Won't start
is the CEL the check engine light that comes on whenever i turn the key and ill try the fuses and fuel pump relay as soon as we have a dry day and no school its been raining awful here for the past few days and not supposed to stop
msheller
Re: Won't start
Mike,
Thank u for going out of your way to post a diagram like that....appreciated
matt
SY2932 said:
Yup:
graham1524
Well-known member
Re: Won't start
in the picture of the 12v to the fuel pump where would the paper clip go to by pass the relay and which one is the relay ??
SY2932
Administrator
Re: Won't start
You would be better off with a short length of wire rather than a paperclip. The fuel pump test connector isn't very close to the distribution block on the firewall. You can see the fuel pump test connector if you follow the wire to where it ends with the blue connector...
The fuel pump relay (#3) is next to the AC relay (#4) on the firewall near the brake booster. These relays are the same so, you can swap them out to see if the one for the fuel pump is bad:
graham1524
Well-known member
Re: Won't start
thanks for the diagram lots of help
im still kinda lost on what to do with the wire i put it in where the fuel pump relay should go and it started but shook uncontrolably and it was awful so i went and bought a new relay was i supposed to use the wire that way or connect it to a totaly different area
graham1524
Well-known member
Re: Won't start
so now have replaced the fuel pump and fuel pump relay tried to start it again today after putting in the relay and nothing still the same thing turn the key and it will just turn over and nothing will happen
next diagnosis is distributor cap anyone think thats a possibility
graham1524
Well-known member
Re: Won't start
checked all the fuses spark plug wires distributor and ignition module and it still turns over but it wont start just keeps turning over
graham1524
Well-known member
Re: Won't start
DaveP said:
It was asked earlier, but I don't see a response from you.
Does the "service engine soon" light come on when you turn the key on? If yes:
When you turn the engine over, does the fuel pump run for 2 seconds, then stop? If yes:
Have you checked for spark? If yes:
What is the fuel pressure WITH A GUAGE at the fuel rail?
There's some more ideas.
no service engine soon light just the check gauges/engine lights
fuel pump does not turn on for 2 seconds.....what controls that ?
we are about to pull and check a spark plug
and getting a fuel pressure gauge tommorow it does pressurize but unsure of the psi
graham1524
Well-known member
Re: Won't start
ok the ecm A and B all 4 test points were getting around 5 volts and i listened and yes the fuel pump is working for the 2 seconds to pressurize the system
thanks for all the help
sly dvl
Ya, it's got a Turbo
Re: Won't start
5 volts? Houston, we have a problem...
