Espritmike
So I my Typhoon running a couple of days ago. I initially tore it down for stalling (162k miles). The throttle tab was bent and it kept running @ 1100 rpm. I found blown intake gaskets and broken vacuum lines, so I assumed I had found the stalling problem . I rebuilt the entire motor, turbo, replaced coolant temp sensor, knock sensor, plugs (UR5 @.28"), ign.wires,cap,rotor and ignition coil (all MSD), had injectors sent out and cleaned (but they were sticking on initial startup from sitting in a plastic bag for 4 months), new oil cooler lines, water pump, alternator, starter (hi torque), A/C compressor, dryer, orifice tube, upper and lower radiator hoses, heater core, heater hoses, PCV hoses and valves, new intercooler pump and hoses,cleaned and fixed all the ground wires, cleaned the throttle body and plennum (all carbon deposits GONE)--------------and it still stalls.
It will run fine on cold start up for 1-2 min then just shut off like someone turned off the key. It will start right up, but if you try to put it into gear it stalls instantly. I can power brake it to keep it running. I bent the throttle tab back to stock after the rebuild because the IAC was at 0. I checked on a scanner now (when it idles) and it stays at about 8-9 (which is probably still a little low). I swapped out a rebuilt ECM and no change.The fuel pump is not loosing power. I'm thinking weak signal from pickup coil, but doubt it.
ANY CLUES anyone??????? GRRRRRRRRR
