Wiring help!!
Injected1
Can anyone name all the items on our truck that need to be relayed? So far I have flashers, horn, hid headlights & foglights. Please help me with any others and and maybe with what type/amp. Thanks in advance.
Nick
sy605
Re: Wiring help!!
Nick
Turbo boost relay, intercooler pump relay, fuel pump relay, a/c relay, typhoon has rear level control relay, prob missed one but thats all I could find in the service manual. Hope it helps.
Re: Wiring help!!
You can always add the infamous starter wire. If you're gonna do a bat relocate then a relay and switch will be required to properly adhere to NHRA rules. Combination NO/NC 30 amp will prolly work everywhere.
What are you attempting to accomplish? Relays add a point of failure but are normally quite reliable. Most relays in automotive use are used to allow small/tiny switches and/or sensors to operate high load circuits. Also helps to keep the use of relatively heavy/expensive wiring to a minimum.
