Wiring Harness Question(s)
jklein68
I'm going to install a Dominator setup, hopefully within the next couple of months. I have the entire front end off and engine out. For guys with aftermarket ECUs, BS3, Holley, FAST, etc. What are you doing with the factory fuse block?
From what I can tell, the ECU harness plugs into half and the headlights, turn signals, etc. plug into the other half.
I'm not sure if you can just remove half, I haven't taken it out yet to see what's underneath. Looks like Harmon just took everything out completely.
Re: Wiring Harness Question(s)
Take it all apart and you'll find 3 major pieces. The plugs you see in the firewall side, the fuse block, and an in-between piece the resides behind the fuse block. The in-between piece has the wiring for inside the cab. Kinda a gooey mess under the connector because of a black almost asphalt like oil, presumably used as a sealant.
How much individual pieces can be removed I can't say. Probably should have a wiring diagram. Anyway, that's what's there, hope I helped a tiny bit.
jklein68
Thanks Don, I'm hoping there's a way to take out the ECM wires but leave the box so I don't have to rewire the headlights, turn signals, etc. While at the same time leaving something that doesn't look like crap.
tbauer03
TRBOBOX
I have started tearing my harness down. maybe I was naive or doing it wrong but I thought everything would pull apart into 2 sections one to the ecm and side to the firewall. But it is a tangled mess appearing to have connectors going in both directions. Do I need to unpin or cut anywires to get this thing separated?
tbauer03
TRBOBOX
I am still digging into it but my areas of confussion are the pink/black wires that converge near the egr connector, the black/white connector going to ground, ic relay, the coil white and pink, and oil psi orange appear to go in both directions
tbauer03
TRBOBOX
The coil has a white wire running to the ecm do I just cut it and save the pink one? And two black/white wires from the fuel pump relay and something else that lead to ground with 5 black/white and a tan wire going back to the Ecm.
tbauer03
TRBOBOX
Dave I got it separated here is what is left.
I just want to check before making any more cuts
Coolant Temp
Large Black Ground
Oil pressure this was hacked up and had 3 grey pigtails from it with just one orange connected the other 2 wires were open
Fuel pump relay
Fuel Pump Test
Alternator
Wipers
VSS
TCC
Fusable link
Junction Block
Coil
AC relay
ABS
IC pump
Starter
Then i have 2 non terminated wires. 1 tan wire 1 tan/black
ABS is gone but i plan on keeping AC
tbauer03
TRBOBOX
Thank you. I appreciate the clarity.
Motor should be finishing up from the machine shop soon and things will start going back together in due time.
68steiny
Dave, do you mind briefly describing the AC setup or do you possibly have a link on syty. I am rewiring the existing harness for a 411 pcm and am going to keep the stock AC setup, but some of the wires are cut. There are 2 connectors for the AC harness portion but I only see 1 connector on the R4 compressor.
Thanks
68steiny
Thanks very much...this will let me do a little more research and see if I can use it. I am not sure of familiarity between the 165 and the 411 but I will be checking to see if there is an AC request and clutch control. I still have the AC wires available on the 411 harness, but wanted to see if the Sy harness would be easier since I am using the same compressor. I'll report back...
