Will this front diff work?
shook0002
I recently got lucky and got a parts blazer (1989) with a 4.3 4x4 and its even got 3:42 gears in it. I'm pretty sure I need a front diff in mine due to a bearing noise. As far as I understand I can just swap in the 4x4 front diff and change the axle tube right? Whats involved in swapping the axle tube over when I get the diff out. Thanks Guys
canadian
sy in progress
Re: Will this front diff work?
Keep it the way it is, add the kit that waller talked about so you can do burnouts and then switch to 4wd!
jwaller
Evil Genius/SyTy Guru
ya. thats the idea. but if you dont like my idea then yes you can just swap out the pass side axle and tube assm and it's all the same. make sure to change all your seals. it's way easier now while it's on the ground.
