will a stall converter give me bad gas milage?
SY756
Just as long as you get a lockup TC, your highway MPG shouldn't change much, if any, due to the converter being locked up under normal cruising conditions. In- town milage will be affected some due to it takes a little bit more throttle to get you going till the converter locks up. I did notice a small change with my 3000 stall, but not much.
Brian Hartman
Yes, I've seen a strange correlation between the level of performance your TC gives you and how it affects gas mileage. The more fun it is to drive, the worse your gas mileage gets for some reason :smile:
No, he's correct, it doesn't affect mileage too much if you have a lockup converter. You might lose 10 miles to the tank if all of your mileage was city driving and your tranny can supply the pressure and volume to make your fluid coupling tight if your TC is efficient enough to begin with. Not meaning to be redundant, just having fun and then reaffirming you had the correct information.
SY756
I will agree with that 100%, that's more than likely where my mileage loss came from. Cant wait to get the PTE52 and 50#s installed this weekend and then try it out. Mileage loss is going to be big-time due to fun factor.:smile:
