who makes a woofer box that fits behind Syclone seats?
FLSY2730
i have a 10" JL box behind the passenger seat of the sy, it fits tight but the seat did not move up any jack
warmpancakes
the jl 10 and 12 box will fit as long as you are not 6 foot 5 and the 12 box fills allthe way to the center console Ken
ghostrider_85
i am tall, so i want as much leg room as possible. someone suggested 8's. i remember a couple years ago a company was making custom fit boxes that you could just slip in and go with, no need to custom make one from scratch....anyone else remember this?
ragilber@hdrinc.com
ROSEDOGGYDOG
umop apisdn w,I
ragilber@hdrinc.com
MTX make fiberglass boxes w/subs but none for our year, they make one for the 94'(i think) s-10. But you can fit two 6" bazooka tubs behind the seats with out moving the seats at all, with plenty of room to breathe, fit a 10-disc changer behind the console, and fit an amp behind the passanger seat. The only mod you will have to do is take out the jack behind the passanger seat and move it to the bed (just grind out the spot welds with a dremel.
ROSEDOGGYDOG
umop apisdn w,I
ragilber@hdrinc.com
FLSY2730
i did the 10" sub on the passenger side and put the amp and crossovers for the front diamond audio speakers behind the drivers seat on a 45 degree angle . i have the diamondaudio speakers in the custom kick panels made for our trucks, alot less foot room. i also did dynomat on the floor and the wall behind the seats, man the truck is so quiet inside driving down the road, anyway jack
7dhamper
E-bay: Item # 599939656
Description: 4 - 10" JL AUDIO SPEAKERS IN 4' BOX
Sorry, I don't know how to link or I would've!
kwick6
The way I show a link is to right click on the page or picture, select properties, the highlight the address by holding down the left click button, then after its highlighted, right click and select copy. Then you can paste it by either ctr+V or right click and select paste. FWIW
Scott
NoClone
I did two 10"s right behind the driver side and huge Kicker amp behind the passenger. I went the custom box route but it fits nice (with out moving the jack). I'll have to get you guys a pic. The custom box was less than $200 bux.
Later
Syclone#892
I currently have some 8"s in my Sy, they are decent but they are basically what my friend calls them Speakers. They are fine if you do not want a lot of bass just a little umph. I will be redoing the speakers and deck next year but this year I am putting in a rockford fosgate amp for the subs and 2 ppi amps (had them laying around otherwise I would only be using one) for the dash and door speakers. My friend knows his stereo stuff and next year were going with Boston Acoustic pros and the dash and doors and some kicker solobaric 12"s, along with most likely the clarion deck drx-9675z they have now or something better if they have one then. My friend said the kicker solobarics are nice because they don't need a big box and they sound awesome. As for the box I will probably have some custom made as thats what my friend says to do because they sound much better. Good luck to you.
SeattleSy#1255
Category 5 Conservative
You get 3 JL10w6's behind that seat in the CORRECT box with a good amp and you'll blow a couple of 10's out of the water....Car stereo, espically subs, are all about the enclosure and power running them! Do it right, and you'll have guys with 12's on there knee's!
nomoty
Still Boosted
SeattleSy#1255 is right W6's are bad ass and don't need alot of airspace to vibrate the hair on your head!!!I know when it comes time for my system in the TY i am going with 2 15" soundstream spl or 2 15" hx2's with a power 800with 8's in the doors and back seat quarter panels but that is a long time from now...A really good set up is a 10" MTX Thunder 8000 ($200 10")in a 1.25 qubic ft. box with a 3" wide 9" long pvc port with a MTX 2150 amp about $250.00 if you can find it crutchfield doesn't even sell em any more they were made 2 or 3 years ago but put it this way brand new they were selling for right at $500...Man I had this in my old 95 mustang GT and it fuckin rocked...Yes the box in the stang wouldn't fit a SY but you could make a 1.25 cubic ft. box that would!!!
7dhamper
Just cut the blow through! If you ever sell you Sy to someone who's ANNAL about it not being stock, tellum to get an S-10 cab and bed when they do a frame off restoration and it will be back to boring ass stock.
I put 8 JL AUDIO 10w0's in my '92 Mazda B2200 and hit 157 DB before I cut the lid off to add a Radical drop top (lost it all the way down to 120 DB with no roof) I put 2 6x8 inch ports, 1 behind the center off each seat, and had a wedge blowing through each hole " // " with 2 10's on each wall. I had plenty of room to mount the amps on the wall too.
natety
How much space is behind the seat in the Sy I bilt a box for a 87 mazda B2000 for three 10" JL 10w0 that slid right behind the seat no movement of the seat, i may still have the plans here somewhere.
7dhamper
The floor is a little diferent. To utilize the most air space, build a box face. Remove the back wall uppulsrty or linning or panel or whatever. Cover the whole back pannel with alluminum foil. Use card board as a template to make the sides. Make 4 side so that you have center deviders for each chamber. When woofers shair air space they may produce the same SPL DB but I can always hear the turbulence of the rear waves fighting each other. I never build 1 big box! Always give each sub it's own chamber unless the only muzak u like iz rap cuz metal sounds like shit when the subs go "whoomp whoomp".
Now if you do this right you will have a flat piece of at least 1/2 inch MDF comming from the floor from the back of your seat's mounts with the seets all the way back, up to the back waal just below the window. Then you'll have 4 triangle with a notch where th 90' right angle would be for the rise in the floor just in front of the wall. Skrew the 2 sides on and evenly space the 2 center deviders to make 3 identicle sealed chambers. The alluminum foil on the back wall and cover the part of the floor that is "inside" the box is so you can slap in some fiberglass and resin and it won't stick to your truck. Use the thickest matting for strength. This will utilize every square inch behind your seats, offering the most air space for your subs, and look sweet covered in carpet, tweed, leather, vinyl, or whatever. Fiberglass work is EZ but the resin stinks, so make sure you have air! You can use a boat repair kit from Home Depot or Lowes to make alost any sub box shape. I'd build it for you for $100.00 but it would'nt be worth the weight to send it.
