Mephisto
These trucks are cursed
alright well i got the white smoke issue...
when i pull the oil filler cap off its puffin like a chimney. so today i pulled off the upper IC and theres all kinds of oil sitting in the bottom of the TB. the PCV valves are shot so i pulled those out too.... i got the turbo to IC hose off and started it up... its puffin smoke out the oil filler out the breather on the drivers side... both pcvs on the pass. side and then when i revved up the engine it was spittin oil out the turbo????
the weird thing is that when i ran datamaster on it, it was fine. stock 15psi and 0* knock... so i dont think its the rings... could it just be bad valve seals leaking oil? or worse the guides are shot and i gotta take the heads off?
any engine gurus wanna toss in their :2cents: ?
