While trying to replace my driver side ext door handle......
John C Holmes
I removed the door panel and white clips didn't come off with panel. Do I need to buy the whole panel because I just don't see the clips or rivet looking things going back on. Also I removed the plastic dust guard. Should I replace with a new one or forget about it. Any tips greatly appreciated. TIA
Cody
turboj91
The white clips need to be removed from the door and installed onto the door panel for re-assembly. There is a special tool to remove the clips while the door panel is still on the vehicle. It doesn't sound like you have the tool (no pun intended with reference to your name - lol). If the clips break upon removal, you can get them at any local body shop or at some auto supply stores. Depending on the amount of damage to the back side of the door panel when it was removed, there may be a way to reattach the clips to the panel (again, maybe a local body shop can help. The plastic cover (actually a moisture barrier) needs to be reinstalled. If its still in one piece, you can reuse it. Make sure it is sealed to the door just as it was when you removed it. If it has a small tear, you can duct tape it. Good luck.
