Wheels
jjorgensen52
NHSTE - I'm the only one!
Re: Wheels
I've heard that they will, the bolt pattern is less than .5 mm different, but I'm not sure how much difference that makes... haven't tried it myself
TurboJunk
questionable
Re: Wheels
WELL bmw bolt pattern being 5 x 114 is almost 5 x 4.75 if you were to massage the holes and the hub part they might go on.
blownamigo
TYed Up Member
Re: Wheels
BMW bolt pattern is 5x120 SyTy bolt pattern is 5x120.65 (5x4.75)
that works fine. Just need to take care of the center bore. BMW
offset is another story, generally speaking you want to look for
older BMW 5 series wheels for the back and newer BMW 3 series wheels
(E46) for the front. If you find a wheel design that is available
for older and newer BMWs chances are that you will be able to
put a set for your SyTy together.
L8r
Blown
