Wheel offset question
Syclone0565
CustomMulticades.com
Have searched for a couple hours and can not find simple answer. (Patience issue)
Front wheel size: 18 x 8.5
Offset 46mm
Will this work on the front of a stock Syclone? Spacer required to sit flush?
Thanks
Will
DanenGraham
Big in the rear
Re: Wheel offset question
10.5" rear with 56mm, is 11mm inset. So you would need a small spacer and longer lugs for the rear. The fronts should be fine though.
EDIT: Make sure to look into the tires as well. Depending on what brand you want and what sizes they have. (check manufactures rollout/dia) Some times the tire you want, doesnt come in both sizes needed to work on some wheel widths. You should be fine, but just something else to think about and look at.
Syclone0565
Thanks, I knew I could find tires that will be withing the 0.0 - 0.2 diameter difference range. Just wanted to make sure the rims would work :tup:
Thanks for your time and help
Will
DanenGraham
Big in the rear
11mm is only .43inches. That's not really gonna matter, right?
It would be fine. But its going to look a little goofy having the rear wheels sucked in. And the longest spacer you can go with stock lugs is about .25" and even then its not many threads holding.
Need a 3/8" or 1/2" spacer, and 1/2" longer studs to have a good (and safe) setup. IMO with those wheels.
