whats that stuff paint shops use after color sanding?
Qwikgmc
Re: whats that stuff paint shops use after color sanding?
666 Sothis 666 said:
what do paint shops use to buff the paint after color sanding????
Rubbing Compound
They come in different cuts -Medium,Fine, etc.
Use a real buffer if you can @ about 1200 rpm
then use a swirl remover, Then regular wax.
Mephisto
These trucks are cursed
Mad Mike said:
I use liquid ebony for a swirl remover.
more details?
i tried rubbing compound and polishing compound, and not to sound lazy, but its a lot of work, for what little results i got. right now im using maguires sratch x remover, which is workin out ok, but if theres somethin better, id like to know.
thanks
Loeryder
last steps we did on mine...
wetsand w/1500 or 2000 with a foam block
use 3m buffing compound with a foam pad, medium cut (Orange color in clear bottle) 2 passes
use 3m buff compound diff foam pad fine (black bottle)
2 passes
use 3m hand glaze to seal the surface
apply by hand with 100% cotton towels (no seams)
Then I hand polished with S100 detail polish.
I have no complaints...
