whats leaking on too my front diff?
sharky207
I was under my ty doing an oil change and i noticed i have an oil leak. Its coming from somewhere above the front differential because its leaking right on it. Do you guys think its a oil line that goes to the oil filter.
Loeryder
Easy to find out.
Clean the lines that go to the oil filter adapter at the block with some simple green.
Get it shiny clean...
Go for a spirited drive and let it sit for awhile to cool then check again.
Mine has a slight drip around the adapter at the block so I ordered the gaskets from GM, like $2 and easy to swap out during an oil change.
Lynn D. Brown
Leaks above Front Diff
John,
In addition to what Jas' said it could be from just about anywhere from the engine, like :
Rear Main, Valve covers, Turbo Oil return line, Oilpan, etc., etc.
