what would you buy?
ThaJokr
Super Member
Re: what would you buy?
I'd go with either a 240sx or an RX-7, but I'd swap an LS1 into them. You can put up the LS1's for cheap now and throw in a cam and you're at 400rwhp with bolt-on's. All in a car that weighs less than 3k lbs.
JayLo
Sir Boost-a-Lot
Unless you have deep pockets for the impending transmission failure from excessive AWD clutch dumps, I would stay away from a TT Stealth. God know what else is super pricey to fix on those.
My money, for a high schooler who wants something cheap, fun and fairly reliable, grab a late ?80s-early ?90s turbo Dodge/Plymouth. Any T2 engine (turbo engines with a factory intercooler) has a stout bottom end (steel crank/rods, forged pistons) and a relatively cheap to maintain SOHC head. Exhaust flange is a standard T3 so turbo swaps are a piece of cake. They're cheaper/more reliable than a DSM, not that that says much.
As mentioned above, a 91-92 Spirit R/T rocks in the bang for the buck category. They can be had for a couple thousand bucks, have the same T2 bottom end (will hold 400+whp reliably in stock form), a Getrag 5-speed transmission (stock will hold 500+whp reliably) and a Lotus 16-valve aluminum head (TIII turbo engine). In proper tune, Spirit R/T?s run mid-14?s in the mid 90 mph range right out of the box.
I picked up a high mileage one for $1300 and had an absolute blast with it. A T3/T4 turbo pushed trap speeds to 110mph on a tired 180,000 mile motor. The biggest shortcoming of the TIII is its tendency to shred timing belts if not properly tensioned. Luckily, it?s a noninterference motor so no valve job is necessary.
________
Brunette Webcams
SloGN
9Sec Alky V6
DSM can be very reliable if they are mantained like everything alse out there you just can't drive the ever living shit of them all the time and expect them to run forever.
I have a 91 Eagle talon TSI (fwd) for my DD. The car has 158k on it and it runs great. I have modded it too lol. It has a B16g turbo a cheap used spearco FMIC , walbro 255 fuel pump and a megasquirt EFI computer on it. The stock exhaust has been cut-off to dump under the pass rear wheel area. @ 16 psi of boost it made 270HP with 276 FT of torque. The motor is all stock. Car still runs strong i drive it pretty hard but i mantain it also thats the key.
NecroWolf
lost marbles member
turbo k-car is a scary thought. you could always look for a turbo grand am.
SloGN
9Sec Alky V6
nah they can be lots of fun. The best mopar turbo car to get is the shadow turbo cars they are the lighest of them all. The 87-88 daytona's are super nice. but are on the fat side of the scales.
MySaudi
i agree here.. my bro has a 92-93 1st gen eclise gsx(awd) with some heavy mods. used to be his DD.. stock motor still runs strongg has about 180k i think or more on it. just needs to be maintainded, like slogn said...
Gr33n
waiting
badmatt said:
skyline R32 or an R33 now
you can pick one up for under 15K
where can you pick up an R33 for under 15k? would it be in any good condition? gtr or gtt?
SloGN
9Sec Alky V6
Ground Rat said:
I'd look at the turbo DSMs or turbo dodges. A turbo 2.2/2.5 swap into a rampage would make a quick and cheap beater, lol. My turbo minivan is a lot of fun too.
Edit - check out this turbo rampage: http://www.maximumpsi.com/rampage.html :D
yeah where ya gonna find a rampage @ they mad those from 82-84. they were all carbed 2.2 engines.
do a search on gus mahon and gary donavon thhose guys have done some wonderful things to the turbo dodge world.
