What Plugs Should I Run?
10secTy
Sy-Ty builder and Tuner
Re: What Plugs Should I Run?
I like TR7IX gapped at 0.028
Nolan
408Typhoon said:
I have a basic stock engine with the vortec heads. What kind of spark plugs should I run?
10secTy
UR's are for stock heads TR's are for vortec heads.
5's are hotter than a stock plug I would not run them you would be better off moving to a 6.
Nolan
sycho said:
NGK UR5's part #2771 work well for me.
sycho
your right, i was thinking l-35 heads. your right, im wrong, your very good looking , im not so good looking.
gjp
another post whore
Did you get the engine dropped in yet. I would like to come by and check it out someday.
Six-is-Enough
Use to do a little Boost
Nolan
Would there be any advantage going to a "racing" plug, so you could go even colder like a 7 heat range? Or would it be to prone to fouling?
It's just a six
Super Member
You would not see any advantage running a colder plug ,unless you are getting detonation from your hotter plugs.
Switching to a fine center electrode will work better than a standard thick/big center electrode.
