What loctite do I want to use on the crank-to-flexplate, and flexplate-to-TC bolts?
VermontTy Support Our Troops Jun 9, 2005 #1 What loctite do I want to use on the crank-to-flexplate, and flexplate-to-TC bolts?
Syclone#1992 SyTy.net Moderator Jun 9, 2005 #2 Re: What loctite to use..... Moved to Drivetrain Tech....
SY2932 Administrator Jun 9, 2005 #3 Re: What loctite to use..... Loctite 262, the red stuff. Don't go crazy applying it, you will only need two to three drops per bolt. Even with that you will need to heat them with a torch to remove them in the future.
Stangbeater How bout it? Jun 9, 2005 #4 Re: What loctite to use..... You will want to use serviceable Loctite 262.
