what do you guys think about this? Should i get it?
nightdiver
id love to have Vortecs on my sy too,but i have overported KB heads
Now for the cam history i think that a cam with 0,50 + lift and some 1,6 rockers will give some nice flow figures
If you got,or anyone else,the balls to rev over 5200-5300 rpm then crane cams has more agressive cams
ill stay with the 5000 rpm governor ........
Irid
Random other head question since we're kicking them around: how much difference in KR does going to aluminum heads make? Either the Vortec's or the L-35's? Or is most of the difference in the combustion chamber design as far as anti-knock goes?
nightdiver
alu heads are the solution for head detonation ! they transfer hear too damn quik and the chance of deto reduces A LOT
BUT they are F expencive
CrazyAl82
On 2002-03-19 08:57, Bob Sacamento wrote:
With clear goals & budget determined... and with our help on the board, you'll achieve them.
so if my goal is low 12's-high 11's and my budget is more than enough (which it is) what do you suggest for my stock ty.
Wes
Dude you need to come check out my friend Bill's Ty. We ran a 12.7 @ 108 on only 18 psi of boost. When we get that sucker up to 24 psi (probably be a few more weeks) it should hopefully be able to break into the 11s. The motor is all stock with just bolt-ons.
fivaxis@mindspring.com
Wes
Dequick single core air-air
ATR cold air intake + battery relocater
ATR headers, downpipe, exhaust with 3" cat
TE 60 turbo
50 lb injectors + 50 lb Ultimate chip
ATR wastegate (seems to work ok but the base psi is only 10psi)
Walbro fuel pump + AFPR
9/11 converter + deep pan + tranny cooler + lockup switch
