supersports10
ok ...i am having a problem.... i found the ads, and xdf files off of code 59, but i am running the 58 code. i downloaded the stock motor 50 lb bin for the ultimate, from tooky's website.
problem is the truck stumbles, and falles on it's face unless you feather the throttle. i have tried like 6 different bins from the 50 lb setup.....no difference!
funny thing is it runs the same as when the stock injector ultimate was tried with the 50 lb injectors
i am currently running e-85 .
when the stock injector ultimate was used with the stock injectors, the truck ran great!
i double checked each time the bin was uploaded, and it verifyed each time.
i also unplugged the ostrich, then tried to start...no start......just to make sure the truck wasn't in limp home mode.
my injectors were from viscious v6?? used 50 lbers
but.....they all were scribed with 58.0 or 58.1 ?????
so should i use a 60 lb bin??
i just wish i could use the t3 24 stock injector bin, but change the injector size to 50 lb in the chip...is this possible??
so does anyone have a 50 lb, or a 60 lb bin that would be a great starting place??
