Ok here is the background and the truck.
http://videos.streetfire.net/video/Life-of-92-GMC-Typhoon_165068.htm
Truck is running good, working through bugs as I get time/motivation.
The base engine is left over from a 67 camaro I owned at one time. It was never built for boost or even this much power, but I had it laying around and had to use it for something besides a dust magnet.
So now that it is running I am honestly happy (for now, I am sure that will change) with the amount of power it is making, how it drives and just generally the truck is fun to drive and with the AWD would probably stomp most cars on the street. It was never built as a race car anyways.
Motor currently is
350 bored .040
Manley forged pistons
stock rods (beamed, polished, etc.)
stock crank
total seal rings
041 casting heads with 2.02/1.6 SS valves
full roller rockers
hyd. camshaft
~9.7:1 CR
Twin GT35 turbos running 7psi (wouldnt' mind moving up to 10 at some point).
ARP head bolts, main studs (2 bolt stock caps)
Generally the truck runs good, went 7.11 1/8th at low boost, non intercooled (it is now). 11.6 in 1/4 on a very hot day. Truck weighs 4,000 lbs.
The problem is at idle you can see it is slightly blowing blue smoke, spark plugs show signs of a lot of blowby. (I have dual breather tanks, 1 for each valve cover).
The motor since rebuilt has always had oily plugs so I suspect the rings are just not cutting it.
So my debate with myself is, in a perfect world I would build a Dart block, forged rods/crank, etc. And not worry about things and be safe to 1000+ hp.
The downside is the bill for just a new block/lower end would be $5k or so.
My other option is to just pull what I have, hone/rering it and enjoy it. Do I go ahead and put better rods/caps in also? Now were talking a $1k bill but I could reuse the rods on another motor later. Still $4k cheaper.
Or do I do option C (you guys fill in the blank).
Just want some opinions as I am sure everybody else has to balance budget and horsepower output.
Wont do anything until this winter unless it just blows up.
Motor currently is
350 bored .040
stock crank
total seal rings
full roller rockers
hyd. camshaft
~9.7:1 CR
