Weird harness question
Can the entire engine compartment wiring harnesses be removed with the engine in the truck?
Thanks.
Slyclone
Well-known member
Re: Weird harness question
I think it unplugs completely at or near the brake booster as a entire harness, plus all the other little connections/grounds.
*Just looked* it unbolts down there not unplugs. Everything else unplugs besides grounds which Unbolt
Thanks. I've had the drivers side partially out. C100 where it passes through to the fuse block. I was thinking more of the ECM harness. Piece of cake with the engine out. Just wondering about if it's in.
Ya, I know there's a gazillion connections. Just makes it fun... Not.
'preciate it
68steiny
Were you able to pull the complete harness out? I am at a point where I would like to do it, but I noticed it is glued in.
Aeroking
e.i.
The engine harness is on the passenger side, and does not have a plug. The only plug is at the ECM. To pull it out, you have to pull the grommet off with it, and pull all the sensor plugs into the cab. Probably need to depin the fuel injector harness plug.
The driver side harness only has a couple engine wires in it. The plug is most likely siliconed in place.
I ended up not removing it. I could have but didn't. The glued in part is "C100" at the firewall. Look in the middle of that and there is a bolt that holds the thing together. The glue is a sealant GM applies. Once you get that connector off look for two small hex headed screws that hold the Fuse panel up against the firewall if you want take the fuse block down.
There are connections at the ECM, dist, oil pres sender, starter, Coil, just to name the ones I can think of.
Why are you thinking of removing it?
My reason was I had a gut feeling that there were poor connections between that harness and the fuse block. So I took it down from inside the cab. Great fun. There are actually three pieces to this mess. The piece you see on the engine compartment side, the fuse block that you see from inside and a third piece behind the fuse block. Huge mess of wires. you'll need patience, perseverance, and caution.
Regarding my poor connections I worked on them but have no actual proof that I fixed anything. I do see a slight increase in voltage at the cig lighter feeding the inverter for the laptop but that is very subjective.
If you ask DaveP he'll probably tell you he's never seen a problem with C100.
68steiny
I was working on pulling the engine out and have been gutting out the complete engine compartment, but previously I did a bunch of rewiring and didn't like the layout of the harness and was considering having a fuse block in the engine bay like more modern vehicles. I am 6'1" and was laying upside down on the seat and the floor to spend time understanding all the wiring...that got old. From some of the other research I did, on the site, it doesn't seem worth it, but I did want to clean it up (egr,abs,cruise,etc).
I have also noticed that I think I can get to the 2 top transmission bolts if I get most of the harness out of the way, behind the engine block...along with other stuff of course.
Thanks for the help, I will see how much of this I can pull apart....or want to pull apart.
Jon
With all due respect, IMHO attempting to change the harness layout is nuts :rotf: there are a LOT of wires. If you're gonna remove the big harness that goes across the compartment the C100 on the engine/firewall side had 3 different connections/looms. The big one that goes across the engine compartment, a small one that goes to the rear (tail lights, etc) and a third that, IIRC is the front lights, ABS stuff. That connector WILL come apart. It's a puzzle but once you figure it out it comes right apart without breaking anything. Then you can remove that harness. It goes through a big grommet at the firewall then to the ECM. disconnect the ECM and I believe those wires will come through that hole. Then you have the harness in your hand. I probably forgot something but that's most of it.
And BTW working under the dash is MUCH easier if you take out the seat. 4 nuts and its out. Big difference.
I would add that having the actual GM wiring harness diag supplement plus the wiring diag manual is almost a requirement. I have both and when doing wiring diag of any kind it's my bible.
68steiny
Haha, yes...the seat will come out next time.
But yes, I agree with you, I don't want to rewire everything...I originally thought I could eliminate the fuse block with a milspec bulkhead, but I don't see that being possible.
I'll go back and play with the c100...I am definitely pulling the engine harness out and rewiring/cleanup.
Thanks for the help.
68steiny
Thanks for the help on this, I ended up getting it all out and keeping the original harness mostly intact. I was then able to go to a yard and get the engine harness portion from a Jimmy.
