T-62typhoon
Which wastegates are most people using? I have a 3" atr downpipe with there wastegate and it doesn't flow enough for a te-62 turbo? Any thoughts..... Jerry Mccoy wants me to to a 46f tial.... Any input would be helpful....
ghettosled said:Your post implies you are overboosting...
the atr wastegates are notorious for being crappy. In my expirience, however they usually dont like making alot of boost. There are some guys who rebuild them and mod them to work better. Or you can run a 38mm Tial, Turbonetics, or ITS wastegate in place. They all take the same wg flange.
The 38mm is fine.. Plenty for a 62 turbo. A 42mm wouldnt hurt but will require re-configuring of both the inlet and outlet pipe of the wastegate.. A 46 or 60mm wastegate not only would require a v-band flange, but would be completely pointless mounted off a turbine housing. Placement of the wastegate is just as critical as the wastegate itself.
T-62typhoon said:I can put a 38 mm tial in the place of the atr without any mods? It will bolt-up no with no problems on a atr downpipe. I hate to waste the money it it doesn't work... Just making sure not doubting your judgement.......
ViciousV6 said:Yes, Tial 38mm will bolt right onto a ATR Downpipe set-up! No modifications.
Ralph
ViciousV6
