InfinitiTech351
NixATripp
Anybody know how to adjust the waste gate properly? i disconnected external boost controller and hooked back up to the factory boost control solenoid, tried to build boost...spitts and sputs and takes forever to build 5psi.... possible bad boost solenoid? Mis adjusted waste gate? Ecu retarding timing? I only see my waste gate rod move when i use the solenoid, when i run the boost controller...the rod dosent move...i already tested the diaphragm from leaks...seems to be working fine with the hand pump...holding pressure.. it launches like a bat outta hell with the boost controller set at 15psi but feels like it loses power after second gear....Anybody have any ideas???? FYI just bought it a month ago...still trying to figure it all out. thanks
