Re: Wanted To Buy: Holley Carb
The Chevelle market (and subsequently el camino) has become very very dependent on documentation, since you couldn't decode by vin.
You ever dig for the build sheet?
Yes, I mention the Tank Sticker (build sheet) above. I recovered it in 1983 the first time the tank was dropped to change the Cali Evap Emissions hoses. It has aged (darkened) quite a bit since, but there's little doubt it is genuine. There are also some numbers on the sheet that can be verified using NCIB data. The document cloners have no idea how to generate these numbers. I had my tank sticker verified by NCRS Documentation Authentication that has access to NCIB GM data. It's the Real Deal.
I believe cowl tag would show dashes for the color.
The "dashes" are a Norwood Camaro thing. Not all plants used the same procedures.
Los Angeles (Van Nuys) use the Dupont formula number. My cowl tag is PNT 926-99616. The "B" is for the black vinyl top.
I did a Google with that number, and
found this. Here's an excerpt:
Notes:
1. While not exclusive to 1970, special order colors seem to be more common with this year. Some DuPont paint code formulas found on build sheets and trim tags are: 926-76248, 926-99568, 926-98371, 926-99616, 926-97249, and 927-98457.
The first 3 digits denote non-metallic (926) or metallic (927) paint. The last 5 digits are the mixing formula for DuPont.
No special paint 1970 El Camino has turned up yet but colors found so far on sport coupes are:
926-97249 is Red
926-98371 is Blue often referred to as Carolina Blue *
926-96881 is Blue is also described as Carolina Blue *
926-99539 is Orange (similar to Pontiac Carousel Red)
926-99568 is Yellow (1969 code 76, Daytona Yellow)
926-99616 is Orange (1969 code 72, Monaco Orange)
927-98457 is Gold Metallic (Tricentenial Gold)
927-99846 is Citrus Green
927-99593 is Metallic Blue (1969 code 71, Le Mans Blue)
Build sheets would annotate a ZP3 special paint code and show the particular DuPont mixing formula codes.
I don't know when this was written, but I sent Dale the Special Paint poop on my 70 El Camino at least 5 years ago. I know his site has been reconstructed since then, and my car is no longer on the Registry, but it was at one time. The next owner can make Dale's day, and show him a ZP3, 926-99616 70 El Camino Tank Sticker and cowl tag.
I suspect not many like mine come up for sale very often.
You ready to buy it yet? :rotf:
