GoatRope
Getting a pretty decent vibration under heavy load, say in excess of 5 psi of boost, worse in lower gears, though will still have some shimmy in 3rd if you load it up. So far I have replaced/upgraded the following:
Front half shafts and ball joints
Heavy Duty prop shaft
Built 4l60E with FTI converter
Driveshaft u-joints
New plugs/wires in wasted spark configuration, no misfires
It almost seems like axle wrap causing pinion angle to get out of whack and create driveline vibrations, so I put some spring clamps on but couldn't get them over the overload springs to really tighten it down. Pinion deflection with a jack was only 3.5 degrees. Spring clamps acted like they might have suppressed some of the issue but it is still present.
Any insight/suggestions are appreciated!
Driveshaft u-joints
