I first had this problem in 03' and since it has been off and on I have tolerated it, seeing as I usually drive in stop and go
Basically I think I need to replace all my vacuum lines, and don't have a clue where to begin. I know I need two different sizes of silicon tubing, but where do I get the elbows/tees/check valves etc? If anyone can help it will be appreciated and maybe my memorial day project.
My turbo builds 5lbs of boost, sometimes it will go up to 15. I removed the vaccum line on the right, looking at the windshield, of the wastegate solenoid, and can build boost to 15 to my hearts content. there are two vacuum lines going to the wastegate solenoid, 1 goes on the left to the turbo, 1 goes on the right from ???, and there is another hole below it with nothing, is this how it should be?
thanks again.
thanks again.
