Upper Plenum ?
DonHo32
OK so I have searched without any luck. Has anyone flipped the upper to the driver's side? If so, any ideas on how to do this (adaptor size, drilling). The intercooler ducting in my truck would be so much more simple converting this. Any help would be appreciated.
Re: Upper Plenum ?
Someone has prolly done it. They've done everything else. :rotf: But on first thought the bolt pattern is not symmetrical and the EGR port on the lower may end up uncovered. And wouldn't that put the TB into the brake master cyl and/or booster? What you want is side to side AND front to back. Tough order.
Just thinkin' out loud...
sharkbait
Re: Upper Plenum ?
who is selling that new upper. he makes it to order. front or pass side TB. is it RPM? its $450 if i remember correctly. ill search for the link.
blk00z28
Forced to by choice
Re: Upper Plenum ?
Hell, why not just go carb style with a plenum that you can put front, back, left, right, or probably towards the back if you want. lol
DonHo32
Re: Upper Plenum ?
I could have sworn that someone here has done this. I thought that they used an adaptor plate. Hopefully someone will chime in.
