Re: upper control arm question
Wheel wobble?? such technical terms here.
I think what your talking about is caster. The relationship of the top ball joint to the lower. EVERY car, aside from maybe an extreme race car has the upper ball joint behind the lower, aka further back. There is an angle formed if you draw a line between the 2 ball joints as looking from the side of the truck. This angle is caster.
The more caster you have the more the vehicle will want to go straight. Less you have the quicker it will react to steering input, and a big concern for us is ruts in the road. I setup any truck I do around 6-7deg of caster.
I have these arms at home, and it truly appears the ball joint location is changed drastically. Sure it might bolt up to the frame but the caster and camber are going to be affected. Get the wrong combination and you will havea death trap on wheels.
I would provide more dimensions, but I have been rather busy last 2 weeks, been home 2hrs in those 2 weeks at most.
