It's just a six
Super Member
Re: upgrade turbo
If you have a 2800 stall converter a 14 cm is better,even for stockish trucks.( Better top end pull )
You do not need to have a loud external wastegate setup,,,,you can use a separate exhaust system w/a mini muffler,, or plumb the wastegate exhaust back into your exhaust system..
The really fast Supras run a much larger turbo than a 25G.
:2cents:
I think a 12cm exhaust housing is plenty big for a stockish truck. Going external wastegate on the crossover tube will give you great boost contorl (if you can tollerate the noise). My goal is not going to be 10's. 12 flat or maybe really high 11's is my goal. Your talking to much money for me when you try and break into the 10s. 11s on the street is plenty fast. Pluss I dont want a caged up truck. A nasty street machine is all I want. Supras run the 25g or also known as the T67. They end up with plenty of top end as we all know.
:2cents:
