I recently tuned my typhoon on a rear wheel dyno here are the numbers:
Build Stock block
Srp .30 over
Eagles
422 cam
Stock l35's
w/ comp springs, ss stock sized valves, comp 1.6 full roller rockers, hardened pushrods, comp lifters
Stock manifolds
Cometic head gasket
Injectors 50lb
Stock turbo/57mm wheel
Stock downpipe
Srp bolts
Stock intercooler
Walbro 255 pump
Stock ECU, tuning with code59
Just wanted to get it running good before I upgrade it with with a larger turbo, injectors and intercooler system, tranny blew right when we took it out for a 1st run, it went right through first and second gear, third gear held fine, so I swapped the bad trans out with a new one I had build awhile back, it works great now
http://s726.photobucket.com/albums/...tion=view¤t=2011-07-19_23-07-05_257.mp4
http://s726.photobucket.com/albums/...tion=view¤t=2011-07-19_22-18-59_863.mp4
http://s726.photobucket.com/albums/...tion=view¤t=2011-07-19_22-13-17_500.mp4
This was on 91 pump, and 16-17lbs boost, the most torque it made was 492 on another run, we were having problems with the stock boost control solenoid, so we just ended up disconnecting it and putting in a manual valve
Build Stock block
Srp .30 over
Eagles
422 cam
Stock l35's
Stock manifolds
Cometic head gasket
Injectors 50lb
Stock downpipe
Srp bolts
Stock intercooler
Walbro 255 pump
