Typhoon Door card escutcheon nuts tool?
Slyclone
Well-known member
You could probably get away with a fork. Some type of pry bar. They make special plastic ones for similar projects.
Sy644
DEAF Syclone
I don’t think it’s bolt on since I’ve got one on my Syclone and it has no threads.
Use 3m double tape
Slyclone
Well-known member
Door cards.. I guess I miss understood. I thought you were referring to whole door panel. Held on by plastic screw in door clips. I guess the " door card" is further up near armrest? Never played with it. There's nuts on the back? If it's similar to the emblems I'm assuming a deep socket. I thought you were working on removing the actual panels from door.
ChrisM
Maybe some kind of safety hex head socket
2500avalanche
Well-known member
No threads. It is a 3m type of tape. Do not pull them as they will bend. Heat a slim piece of metal and do a little at a time.
ChrisM
Yes I'm aware of that. supposedly these nuts are called escutcheon nuts from gm they hold on the door panel leather card insert from the back side of the door panel
