Ty smokes at idle:
G
Guest
Guest
I have a93 Ty smokes at idle , run,s good ,but smokes at idle , any answer,s please help . thank,s
lavaman
envision whirled peas
blue smoke: prolly burning oil
white smoke/steam: coolant
black: running rich
smoke coming from where? my online diagnostics sketchy though....
Terry
Sy769
Try not to post a problem in multiple sections.
What do the plugs look like after it idles for a few minutes? Plugs can tell you lots.
Sy769
Could be but you are going to have to give use some more details and do some investimigationing. :wink:
*Check the plugs after it idles for a few minutes.
* While it is idleing see how much blowby you have.
*Do a compression test.
*Can you see bubbles in the coolant with it idling. (pull the radiator cap off while it is cool then start it)
Any water in the oil.
IMO U should do these things before you make another post. That is unless you want a bunch of WAGS (wild ass guesses) Now if you want a SWAG (scientific wild-ass guess) go check those things and report back. :D
G
Guest
Guest
Thank,s for the help I,ll check it out and get back to you , thanks
MattGE
Here are a coupla easy oil tests to see where your probs may be:
1. Pull your dipstick and put a lighter to it. If the oil flames up, gas is persent in the engine oil
2. Drip some oil from the dipstick on the hot turbo/manifold. If the oil bubbles or boils, there is coolant in the oil.
Sy769
You played with fire as a kid didn't you? :p
MattGE
Lol. Oh, did I mention you should have a fire extinguisher handy? :lol:
