Ty rear shocks
Shopping4Ty
Anybody ever disconnect rear leveler on TY and put on regular shocks?? If so were the results good or bad?
Need suggestions for front shocks also, and is the ATR sway bar worth $200??
ParTyBoy
Re: Ty rear shocks
Yes lots of people have..... :roll:
And if you would have searched the shock threads you probably would find info about the sway bars at well... and no the ATR bar is not the bar you want...
mattw
I will make it easy for you...
You want KYB shocks with a Suspension Techniques rear sway bar.. Ditch the leveling system and the pump and all of the other associated garbage that goes with it...
1BADSUV
Shock's
Shock's
I went with Bilstein HO's front and rear with the ST sway-bar and 3" lowering block's and it is rougher than stock, but it handle's alot better. My Father went with Monroe Sensatrac's front and rear with stock height and the ST sway-bar and he has a smoother ride in his 93' Typhoon.
Cheer's
