Ty died after 2-hour drive....won't start until it cools
LowLife
Drove the Ty for 2+ hours on Sunday........the truck died while doing 50mph. Got it pulled on the shoulder and popped the hood.....nothing I can see wrong. Waited 15 minutes with hood open and then it fired right up! Drove it 5 miles and it went dead again.....this time it wouldn't crank. Had to have it towed home. Got it home and unloaded it from the flatbed.......and it fired right up! :rant:
No Check-Engine lights at all....nothing out of the ordinary.
Any ideas? Sounds like a sensor to me maybe? I'm not sure what to check first though.
Thanks for the help!
alwayscode390
pppssssshhhhhtttttttttttt
Re: Ty died after 2-hour drive....won't start until it cools
I would say Vapor Lock , until you told me it wouldnt crank. ---
Throws
Oil pressure sensor?
-P
TNPhoon
1of28
We had a car here (non-SyTy) that was doing that. IIRC, it was a sensor, possibly the crank shaft sensor IIRC?
Oil pressure sensor might cause it to quit but not to not crank. Z little gray cells are still cogitating, but I suspect a electrical fault. Or maybe 2. Starter won't crank because it's hot (but works fine when cool) and OP sensor. Do you have a fuel pressure gauge installed so you can watch? Also everything you're talking about goes through the key switch. Maybe a failure there of some kind? Do you have an alarm?
Flyin Ryan
hated cuz he drives fords
ignition module is my guess
Throws
The no-crank part throws me... Maybe Don is onto something with the key-switch.
-P
Jimmy
Banned
Pull the vac line off your FPR and tell me if it smells like gas.
Wait,I missed the no crank part. No crank is the purple wire that goes to the starter solenoid.Replace it from the loom above the brake booster with some 10 gauge wire.It is the thickest purple wire in the loom.
LowLife
thanks guys! all great ideas.....I will report back after I do a little digging into your suggestions! Thanks again!
wildphil
I Love My Ty's
That is kind of a odd thing with it not even cranking. Something like that was happening to my neighbors vehicle. The problem on this vehicle ended up being a battery cable corroded and not making good enough contact sometimes. It was weird lights,radio,and horn would still work. But at times it would not turn over. May not be your problem. But does not cost anything to check.
vinnieTy
TY # 1889
When you state wont crank is there power at other places, like lights, radio, bla bla bla!! I had a similar issue and it was the wire harness behind alternator it has the fuseable link on it or a fuse i think its called a fuseable link anyway was loose and when i made a turn the truck died once i was driving straight started right up, hahah you never know.
The Bronze
My guess: Ignition module. The second time it died and wouldn't start perhaps you left it in gear. That makes more sense than anything else.
