Ty#0318 rebirth
Chest Rockwell
Re: Ty#0318 rebirth
Home. Sweet home
Beautiful truck, but what's up with the manual mirrors? Those Dumbo mirrors look a little out of place.
Ty#0318
Re: Ty#0318 rebirth
I'm after refreshing the engine...
After few days of happiness engine don't want to start.
I've found that engine oil is much over the level and is mixed with a fuel.
Today I have checked injectors. Two of them leak very badly.
Ty#0318
Re: Ty#0318 rebirth
New cylinder heads installed.
After two months of wating I get a new turbo cartridge.
Some 10mm spark plug wire arrived too.
Distributor
And a face finally...
Ty#0318
Re: Ty#0318 rebirth
THANKS
It was like below after it lost compression. Crooked pushrod caused compression problem but I found it after heads unscrew.
New heads
I've installed upgraded steering shaft too.
Ty#0318
Re: Ty#0318 rebirth
I get new oil indicator tube finally. I had to remove turbo and header once again to install it correctly.
Gentlemen you won! Original mirrors on place. Added handle frames too.
I have to replace fuel lines with a fuel sending unit and tank now.
Then after a year I will try to start the engine.
I can't wait.
Ty#0318
Re: Ty#0318 rebirth
He is alive!
I had to find a new TDC point and adjust ignition. Additionally it was 180 degrees switched.
Have a problem with opening windows. Is litte black box under the dashboard (driver side) which immitates "beep" sound windows opening module?
I burned it...
The project has been completed. Typhoon has been described in the Polish TopGear magazine.
I am sending some pictures. Enjoy watching.
Ty#0318
Re: Ty#0318 rebirth
Oh, my heater core exploded today. All the carpet wet.
I found ground pins in the ecu burned!
tunerpike
Re: Ty#0318 rebirth
Wow... Very nice work, I have been following your build and just saw the post regarding the magazine article.
Bullydawg
Mo' Boost Mo' Problems!
Re: Ty#0318 rebirth
Sweet build! Love the red carpet! I am going to go back to red on my firebird one of these days!
What are the wheel specs? Offset and widths? I am going to try and run a set of Work Equips I found out here in Japan...
