turnerpor questions
juicehead9
93 Typhoon # 0973
OK got the ostrich up and running, but turnerpro does not see the aldl, i tried changing the com port and no go. And it idels high about 1000 rpm how do i bring this down in turner pro?
sy#2921
BAMF
Re: turnerpor questions
sent ya and email and a new bin with a lower idle and some intructions how to change from there
Its tables f13, f18 and f19
juicehead9
93 Typhoon # 0973
Thanks, now a new prob. when i un hook the usb cable from ostrich it goes into limp mode?
sy#2921
BAMF
Sounds like it might be aldl mode since you havent loaded the ostrich with a bin file. When using tunerpro to emulate there is no bin "saved" to the ostrich. I use the emulity to load the bin to the ostrich when I am running without a laptop.
juicehead9
93 Typhoon # 0973
not aldl mode unhooked aldl cable and sent file to ostrich and tried unplugging cable it went into limp mode again.
turbodig
Battery in ostrich loose/bad?
Loose/sensitive connections at EPROM adapter? (Very common)
juicehead9
93 Typhoon # 0973
Battery shouldn't be bad just got the Ostrich 3 days ago, even with the computer off if I pluged the USB cable in it would run right, now if i unhooked the cable with the computer on or off it would go into limp mode
skwayb
NWSTP
The ostrich has nothing to do with ALDL at this point. Are you sure you don't have an Autoprom? With the Autoprom you could run into a problem if you have the switches on it set incorrectly.
If it is an ostrich, I would contact Moates at this point. Sounds like there could be a problem with it.
MRKING
New Parts for Old Trucks
I love the ostrich , but mine DID come with dead batteries ..
juicehead9
93 Typhoon # 0973
I will try again when i get the chance this weekend, would it do this if the Ostrich battery was dead?
This is the procedure I use to use the Ostrich. plug the usb cable into the usb port on my laptop, plug the usb cable into the Ostrich, start tuner pro, find the bin I want to use,click the up arrow to load the bin to the Ostrich (it say upload complete or something like this) then I click the emulation butten, make changes with turner pro click the change butten all done.Crank the TY I unhook the usb from the Ostrich and it goes in limp mode?
MRKING
If memory serves its a 9v . The ostrich will get power from the laptop if its batt is dead , maybe thats why it goes out when you unhook it .
skwayb
NWSTP
has it ever worked? Almost sounds like you have the cable at the ECM plugged in backwords...
juicehead9
93 Typhoon # 0973
f i plug it backwords it will not crank or run. No i have never had it to work just got it a few days ago. I tested the batteries they checked out good. Am I supposed to unhook it some special way ie.. turn tuner pro off first then unplug the cable etc..
SBNova
Try saving your bin which will recalculate them checksum, then bring up the checksum and "update" it so you loaded bin has the most recently calculated checksum. Then try disconnecting and see what happens.
skwayb
NWSTP
If it is plugged in backwords it will be in Limp Home mode. As the chip will be seen as bad. I am talking about the ribbon cable end that plugs into the ECM. That should like it is in backwords. Won't hurt flipping it around.
This is how it should be plugged in.
