Turn signals, making needles on gauges flash up and down
Supersix
Has enyone ever encountered when there turn signal is on the gauges go up and down with them...also when you press on the brakes when you have the hazards on the hazards stop flashing?...Thanks ..
psmvchaser
I've got a better one.
Whenever my turn signal clicks on or off, my windsheild wipers turn on.
Pretty stupid, but I am not an electrical specialist.
tyRod
turn signal
turn signal
You (psvmchaser) need a new turn signal switch. It all comes together stalk and all.
Rod
G
Guest
Guest
My rear windshield wiper switch turns the front windshield wipers on and vice versa. :evilbat:
V
Re: Turn signals, making needles on gauges flash up and down
It's supposed to work like that.
G
Guest
Guest
Normal operation is when just the Battery gauge goes up and down when the signals lights up. Never seen all the gauges move before though.
ItsMyTy
Life is beter at 25 PSI
need a new wiper switch
they do that when they get worn out
There's a ground under the dash by the e-brake release I think. Check that.
My gas gauge use to go way down when I turned on the lights. I'd turn them on and tell people I needed gas money or they had to go :lol:
