TurboTweak Velosyty Syclone/Typhoon Chip Only. E85/80lb Siemens/ 3 Bar Map $100.00
blownoutlaw New member Oct 27, 2020 #1 TurboTweak Velosyty Syclone/Typhoon Chip Only. E85/80lb Siemens/ 3 Bar Map $100.00
blownoutlaw New member Nov 22, 2020 #3 Yes sir single program. 65mm precision turbo Vortec heads Custom grind comp cam. E85 fuel
IGottaSy Active member Nov 22, 2020 #4 Oh, okay. Would you post the timing/boost the chip is programmed to? My truck is all stock except for a turbo upgrade.
blownoutlaw New member Nov 22, 2020 #5 Timing 19 degrees at WOT The timing will vary with rpm Same as boost but chip will be good to 20psi I have the order # for chip so if you wanted Turbotweak to change anything for you they can no problem.
