Re: turbo and cam suggestions
With a stock Nitraded crank I would not go for much beyond the 700hp mark. It will live if pushed once in a blue moon above that point but not for long.
With that and the fact you want a tight stall I would run a dual ballbearing PT-67 ptrim.
We just had a motor on the engine dyno yesterday that was a stock block, stock crank combo with vortec heads, stock intake, ATR headers, stock intercooler with pump gas and meth. It made 670hp and 770lbs at 23psi. With more boost and a good intercooler 700+ hp would be pretty easy. The spool of that turbo was insane!!
As far as cam we used our custom cam.I would not use a 422
Nolan
NecroWolf said:
okie dokie nolan,
i got a fast stand alone, forged pistons, rods and i'll probably order a nitraded crank to go with the four bolt main conversion. i'm looking for max power without splitting the factory block, since a bowtie is a little out of the budget right now. so i'm figuring on a dbb turbo but i'd hate to go above 3200 stall on the tranny. i was kinda leaning toward a gt35r but i'm not really sure.
