Tunerpro Rt v 5 Data Errors
Inferno
I searched here, google, and even binged it. I have Moates Apu-1, tried datamaster for past few days, two laptops no connection I did read every manual and played with usb settings and timings... lets skip that. Going to use Tuner pro, I can connect but get connected / data error / connected / data error back and forth almost non stop.
Issue I am trying to find is why as soon as I go into boost my truck starts misfiring crazily, I do have a wideband and she goes kinda rich 11-12ish.
New engine
New turbo
Turbo Tweak 60# injectors
I beleive Diggs 60# bin
My coolant gauge isn't working on dash, but I don't know if its sensor or gauge itself hence why I wanna see data...
Inferno
Re: Tunerpro Rt v 5 Data Errors
uninstalled, re-installed v4 (been a long time since I used) connected and works perfect.....
my dash gauge started working again ( can't have anything to do with each other ) all gauges are working both in tunerpro and on dash, still have crazy misfires and voltage on o2 sensors is going to 0.00 on accel. wideband still shows 12-13 range under accel which I though meant rich, but plugs are very light in color... I'm search more... hopefully yall got an idea :)
Inferno
almost yes, I'm not going to keep running her until I have better ideas, I pulled the plugs again and they don't look healthy... not dark unhealthy, but lean or to much timing unhealthy... :(
