Re: Trying to get ABS light out with no luck
I was able to borrow a nice fluke multimeter today and I can confirm something is screwy with my multimeter. Also the 200 ohm selection on it started working last night but the ohms it was reading are way off the fluke by about 20. I am never buying a crap multimeter again.
If you don't worry about resistance, a cheap meter is usually within 1% for voltage and that is more than close enough. My trail bag has a $20 meter, as does my comm bag. I pull out the good one for calibrations only.
I was able to get a good reading on both the voltage at the aldl and measure the resistance in the ground at the 10 prong connector. The meter register 6ohms of resistance at the connector and the voltage read 4.42 volts jumpering A and H on the aldl. I did not connect the aldl to a separate ground.
If you provided a better ground, did the lights flash/PCM reset work as intented? Likely not as the ground was good enough to register the voltage difference and the circuit doesn't need much ground to work correctly.
To Bronze: The voltage when the 10 prong connector is connected to the ehcu reads 4.42 volts on the aldl. If the 10 prong connector is disconnected the voltage reads 0 at the aldl and the light goes out.
Good. Removing the 10 prong connector removes the ground path for the ABS light (and one path of ground for the BRAKE light). That means the EHCU is the reason the light is on.
The disconnected 10 prong connector reads voltages betweeen 11-12 on the ground wire connecting to all wires except the white wire that is for speed input. That wire reads nothing. You also referred to pin J, is that the white wire for speed input? The J pin on the 10 pin connector would have to be number 10 so it is either the pink/white ignition wire or it is the white speed input.
PIN J is the Black/White ground wire. PIN F is the white wire. That wire is the diagnostic enable wire. You know the one- it reads 4.42V at the aldl.
It won't have voltage as it is generated at the EHCU. Speed inputs come from the ABS wheel speed sensors only. With the rest reading 12 volts, that means:
1) You have EHCU power on PIN A.( If you were missing this, you would be checking the brake fuse). Test=Good.
2) The ABS light ground on PIN B (it has power that is waiting on the EHCU to provide the ground to illuminate the light once you plug it back in- remember that until a ground is provided in an electrical circuit, there is power on both sides of the load (electrical device)). Test=Good.
3) PIN C. Purple wire. You have power through the brake switch (pedal is NOT depressed). Pressing the brake pedal would block power to the EHCU on this wire. Press the brake pedal and watch the power vanish.
THEN Test=Good.
4) PIN D. Brown wire. Front axle switch. Funny, I didn't think this wire was there on a Syclone (I removed my harness). Someone else can verify. It does make sense as it wants to know if there is a connection between the two axles. I am too lazy to walk out to the garage to check the front axle or to perform a search. If it is there, then it should have battery voltage as well. Test=Good.
5) PIN E. Nothing.
6) PIN F. We discussed the diagnostic enable earlier. Test=Good.
7) PIN G. Nothing.
8) PIN H. Tan/White. This is the BRAKE light ground path. Same as #2. Should be power there unless the brake pressure switch trips or the E-brake is engaged. Engage e-brake, power should vanish.
THEN Test=Good.
9) PIN J. Black/White. This is the EHCU ground wire. Super-duper important.
I would do this test a little differently. I would leave the unit plugged in. After all, isn't that how it normally works? Backprobe the wires to the EHCU. PIN A power? PIN B ground (mV reading) with the ABS light on/ Battery voltage with the ABS light commanded off? PIN C brake switch. Engage/disengage the brake pedal and watch the power cycle from battery voltage to 0.
PIN D. Ugh. somebody look that up or I will edit this tomorrow. :roll: PIN F About 5V with the ALDL NOT grounded. Ground it and it should drop near 0V. PIN H Grounded if the BRAKE light is illuminated. Battery Voltage if the light is off. PIN J Ground wire. With the system OPERATING, you should only see some mV (millivolts/ .xxxV) Nothing with a number to the left of the decimal!
Don't trust wiring to the ALDL? Just ground the white wire at the connector. You can clear the codes there as well doing the ground white wire for two seconds, remove for 1 second and then ground for 2 second procedure.
If the inputs are good and the EHCU won't pull/clear codes or flash the light by providing a GOOD solid gound path, then there is an internal fault.
<SOMEONE COULD INSERT THE GM ONE-PAGE WIRING DIAGRAM HERE>
EHCU is bad? Good; remove it and the rest of the ABS before you smack into the back of a van.
