I recently tuned my truck and it has been running perfect, well yesterday I started it up, idled perfectly and took it around the block parked plugged in my ALDL cable while the truck was running, the RPM's revved up to 2K, and then dropped to about 1K, then the engine started stumbling badly, and shut off. So I disconnected the ALDL and the truck kept stumbling very badly and could not stay running. Ive tried resetting the fuses inside the cab, pulling the prom out re-seating it, swapping ECU's, proms, tried emulating from my laptop through the Ostrich, check the grounds to the ECU, now when I turn it on the RPM's stay at about 2k but if they fall under that the truck dies, I have no idea what happened, I've checked all my connectors in the engine bay, I thought the ALDL shorted something out but I swapped the ECU, I dont know what to do at this point, when the truck is idling it is in open loop so a/f wouldn't effect how the truck runs, I was thinking maybe the wide band unit I have shorted out and in effect does not let the truck run, any suggestions thanks
